Old 26th April 2019, 06:24 PM
Default Friday Evening Quiz
Anybody wants to guess what this means?
Old 26th April 2019, 06:39 PM
Your overhead mains supply has snapped?
Old 26th April 2019, 06:49 PM
That's a bit small for mains supply, mine is underground, and the question was a bit more 8 related.
Old 26th April 2019, 06:57 PM
Ours is overhead, a single cable about 18mm dia. Before the most recent upgrade it was two smaller cables, maybe 12mm each?
Difficult to tell the size or see any details in that low-res photo......
Old 26th April 2019, 07:06 PM
I scaled it down to 25% not to take up too much screen estate, it's 3x1mm2 cable, around 6mm outer diameter. I could have put a £1 coin next to it for scale but thought size of paving blocks should be enough.
Old 26th April 2019, 07:09 PM
I'm going with 'drove off with the battery charger still connected / shut in the boot'
Old 26th April 2019, 07:12 PM
Yep, wife with kids drove off in S8 while it was still on the charger, did not notice the cable. I was moving S4 out of the way so they could get out and did not think of it but I am sure if I was going to S8 I would have noticed cable.
Old 26th April 2019, 07:20 PM
Oops! Done that myself, but I have an extension on the CTek so that just popped out without doing any damage.
Old 2nd May 2019, 08:42 PM
27litres's Avatar
27litres 27litres is offline
New Ctek on the way then!
If you get one of their 25amp kits, you get a 0.8amp maintenance charger with it...
(Or at least you used to, I've been trying to find it!)
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 4th May 2019, 04:58 PM
It's just extension cable, cut off a meter or so of it in reconnected so all good. Even if it was charger wire I would just replace wires.
And I do not see any benefit of having Ctek anyway at the 4x cost of my charger.
