Thanks Architex,
I’m still trying to sort out my misfire issue and +25 fuel trim on bank-4 so looking out for anything abnormal. I’m prepared to replace Lambda sensor and clean injectors but i understand the inlet manifold flaps can break off and cause the mixture to be off... I’m taking it all apart again on Monday but VCDS activating the intake manifold test first and will inspect with a camera. Otherwise I’ll continue on to remove and service injectors and replace Lambda S1 Bank-4 while i’m At it. Fingers crossed... Thanks again...
Present cars Daily driver: BMW e65 730d Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry. ![]() |
Update
Ok so all apart again. Completed intake manifold activation test with VCDS and flaps look perfect. I have removed the injectors sending to service and test. I had one stuck injector and after waiting on the eBay sourced, FSI removal/installation kit - injector was removed fine. Research on eBay I found: Injectortune in Wiltshire, can do these injectors so fingers crossed all returned by next week. The challenge now is replacement seal/fitting kits. So far China has these with 2-week lead time. Waiting on Audi to quote... I’ll update as this develops (this is taking rather long) Cheers
James at injectortune runs a D2 S8. Or at least did in the past. He did 10 injectors on mine. All good...
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment ![]() 2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot 2022 Mercedes EQC 400 Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS 2008 A8 3.0 Tdi sport, B&O |
Bank 1. System too lean at idle. P2187 - 004 Mixture regulation Bank 3 range 1. P1081 - 004 - lean limit exceeded - MIL on. Mixture regulation Bank 4, range 1. P1085 - 004 - lean limit exceeded. Looking at the above can anyone suggest additional checks... it looks to be a vacuum leak... possibly? I can not remove the oil filler cap with the engine idling due to tremendous vacuum - is this normal? On other web threads this points at a faulty oil separator - please let me know what is normal. I’m at my wits end on this car - so much work and No cigar... Thanks guys,
From memory the oil seperator / pcv valve isn't hugely expensive on the D2 so perhaps its an idea to change it and see if it resolves things and gets you back to smooth running
Thanks Architex,
I have ordered a new breatherAGAIN but the more costly one. The £38 one was only recently fitted and must be a dud..... I’ll report again on progress. Cheers,
Hi, today a fitted another new PCV oil separator and also vacuum tested the fuel tank breather solenoid valve N80 (tested ok). Started the engine and I am now able to remove the oil filler cap with engine idling (well I couldn’t before). So it just goes to prove that cheaper parts on EBay £32 compared to the better £80 Bosch part makes one hell of a difference in quality and function.
Next step - check VCDS for Lean operation after completing my recovery from retinal detachment surgery, hopefully early next week. Fingers crossed, Thanks again folks!
#30
Update, well a few hundred miles later and all is well with the car. Idling smoothly, starting and running very well and no engine fault codes - great.
Thanks for all your comments and support�� It’s been a costly and time consuming project to get this car up to the level it’s at. Thinking on a new project now so may consider selling the S8 next. Cheers
