Old 28th May 2019, 10:21 AM
RS6's Avatar
RS6 RS6 is offline
The antenna is attached from inside the rear quarter. You'll need to remove the boot side trim to get to it, and iirc there's one bolt holding it to a bracket. It then drops down out of the rubber grommet - the force it needs can be quite scary as they're all pretty crusty by now. If it's stuck, tt helps to drop some lubricant (WD-40 etc) down between the aerial base and the gromment from outside, and then wiggle it around a bit to free it. The grommet is then just a push-fit in the panel.
There are a couple of versions of the aerial base depending on which options the car has (phone prep etc), and it has different connectors accordingly.
Does this look about right?
http://www.audipages.com/Tech_Articl...nnaremove.html
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
