D3 - Interior Trims Seats, dashboards, plastics, everything inside the cabin |
Hi again guys yet another problem with the a8, i came out the house this morning to the drivers footwell full of water, i left it as had no way of clearing the water and after pulling away and turning right out the street i heard a swishing noise and some water come ****ing out between the c pillar trims at the passenger side and soaked the seat.
We did have a bit of rainfall last night here but this is the first time iv come out to this ![]() has anyone had any water ingress issues similar to this? It would be good to hear if anyone can shed light or give me somewhere to start if they have had something similar to this thanks ![]() |
Its a common fault, and as such has been mentioned many times and documented here in a few different threads.
Its not recommended to push a welding rod down the tubes as that can puncture them and leak cause leaks into the car. Usually though they do block requiring regular maintenance. I personally use a bug spray bottle modified to squirt the crap out of the tubes. Scuttle area also needs constant attention if you live anywhere near trees.
Del ![]() |
Not that it's of much use, but here is where the sunroof drain tubes run and what it looks like behind the roof panels (not mine btw).
![]() ![]() ![]() ![]() As Del said, it's not the best idea to ram an arc welding rod down there like you're ramrodding a 17th century cannon, or even blow compressed air down the tubes. With the former, it's likely you'll pierce the rubber lines somewhere, and with the latter it's likely you'll rupture the brittle rubber, or blow the top of the rubber tube away from where it's secured. I've used Del's method before, adapting a bug / chemical sprayer and using warm soapy water and it worked well. Might be a good idea to check the bungs / drain tubes in the centre tunnel. You can find them in the central tunnel and peeling the carpet back a bit. ![]() ![]()
Currently '8-less Previously: - Aqua Blue Pearl D3 S8 - Kamut Beige leather, ACC, B&O, factory RSE, solar sunroof, electric blinds, ski bag, Homelink, comfort headrests. - Aqua Blue D2 S8 - Grey leather/Alcantara - D3 A8 3.0 CVT - D3 3.7 V8 Last edited by Conquistador; 29th May 2019 at 02:47 PM. |
