Old 24th May 2019, 11:49 AM
Originally Posted by Prefferle View Post
I’m considering that I may have a defective PCV/Crankcase breather-oil separator valve. This would actually make some sense as it is located at the back of the engine near bank-4.
If you remove the oil filler cap whilst the engine is running and the variation in engine speed / rough running improves significantly then it is likely it could be the PCV valve for sure
Old 25th May 2019, 07:16 PM
Prefferle Prefferle is offline
Thanks Architex,
I’m still trying to sort out my misfire issue and +25 fuel trim on bank-4 so looking out for anything abnormal.
I’m prepared to replace Lambda sensor and clean injectors but i understand the inlet manifold flaps can break off and cause the mixture to be off...
I’m taking it all apart again on Monday but VCDS activating the intake manifold test first and will inspect with a camera. Otherwise I’ll continue on to remove and service injectors and replace Lambda S1 Bank-4 while i’m At it. Fingers crossed...
Thanks again...
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
Old 29th May 2019, 06:47 PM
Update
Ok so all apart again.
Completed intake manifold activation test with VCDS and flaps look perfect.
I have removed the injectors sending to service and test. I had one stuck injector and after waiting on the eBay sourced, FSI removal/installation kit - injector was removed fine.
Research on eBay I found: Injectortune in Wiltshire, can do these injectors so fingers crossed all returned by next week. The challenge now is replacement seal/fitting kits. So far China has these with 2-week lead time. Waiting on Audi to quote...
I’ll update as this develops (this is taking rather long)
Present cars
Old 29th May 2019, 07:23 PM
kele kele is offline
James at injectortune runs a D2 S8. Or at least did in the past. He did 10 injectors on mine. All good...
2022 Mercedes EQC 400
2008 A8 3.0 Tdi sport, B&O
Old 21st July 2019, 05:06 PM
Default The sage continues lean codes and V10 rough idle
Hi all, so now all injectors serviced by Injectortune, and refitted with new installation kits, new Lambda sensors bank 2 and bank 4, new Oil separator fitted, and still having this intermittent rough idle. After spirited driving the CEL is on again with the following codes by VCDS:
Bank 1. System too lean at idle. P2187 - 004
Mixture regulation Bank 3 range 1. P1081 - 004 - lean limit exceeded - MIL on.
Mixture regulation Bank 4, range 1. P1085 - 004 - lean limit exceeded.
Looking at the above can anyone suggest additional checks... it looks to be a vacuum leak... possibly?
I can not remove the oil filler cap with the engine idling due to tremendous vacuum - is this normal? On other web threads this points at a faulty oil separator - please let me know what is normal.
I’m at my wits end on this car - so much work and No cigar...
Thanks guys,
Present cars
Old 22nd July 2019, 08:24 AM
From memory the oil seperator / pcv valve isn't hugely expensive on the D2 so perhaps its an idea to change it and see if it resolves things and gets you back to smooth running
Old 22nd July 2019, 09:33 PM
Thanks Architex,
I have ordered a new breatherAGAIN but the more costly one. The £38 one was only recently fitted and must be a dud.....
I’ll report again on progress.
Cheers,
Present cars
Old 30th July 2019, 07:06 PM
Hi, today a fitted another new PCV oil separator and also vacuum tested the fuel tank breather solenoid valve N80 (tested ok). Started the engine and I am now able to remove the oil filler cap with engine idling (well I couldn’t before). So it just goes to prove that cheaper parts on EBay £32 compared to the better £80 Bosch part makes one hell of a difference in quality and function.
Next step - check VCDS for Lean operation after completing my recovery from retinal detachment surgery, hopefully early next week.
Fingers crossed,
Thanks again folks!
Present cars
Old 30th July 2019, 09:03 PM
Old 5th September 2019, 03:48 PM
Update, well a few hundred miles later and all is well with the car. Idling smoothly, starting and running very well and no engine fault codes - great.
Thanks for all your comments and support��
It’s been a costly and time consuming project to get this car up to the level it’s at. Thinking on a new project now so may consider selling the S8 next.
Present cars
