Go Back   A8 Parts Forum > A8 D4 > D4 - Everything Else
D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out
Old 25th July 2019, 10:46 PM
Default Interior Trim
In the D3 area Tech Dump there is a PDF of "How to" the interior trim.
Does anyone have access to something similar for the D4?
Old 26th July 2019, 06:59 AM
You're not taking your new car apart already are you Ray!?
Old 26th July 2019, 09:39 AM
Just two little things.
  • Previous owner has a mini usb lead at the right end of the dash. It's connected to the right hnnd fuse box but I do not want to just pull it out.
  • I have a phone holder/charger that is currently plugged in to the cigar lighter(?) in the cup holde r. I want to hard wire it to the rear of the cigar lighter.
Just tidying up.
Old 26th July 2019, 11:20 AM
Try here Ray - http://forum.a8parts.co.uk/showthread.php?t=8379
Old 26th July 2019, 10:59 PM
Thanks Neil . . . . But. . . .
That is where I have looked five times now and I cannot see anything about internal trim.
Old 27th July 2019, 12:31 AM
H-M3 H-M3 is offline
Message neeldub he is normally good at that.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 29th July 2019, 01:06 AM
neeldub neeldub is offline
Many thanks for recommending me lol.
I will soon compile a pdf with instructions on how to remove interior trims on the D4.
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 29th July 2019, 08:36 AM
Already in PM mode with Neel
But many thanks for the pointer
Old 29th July 2019, 06:21 PM
No worries
Old 31st July 2019, 12:00 PM
Problem solved.
I had ELSA Win installed on my PC. Cost £30. Was supposed to take 4 hours to install, mine took 2 hours.
  1. Took off the fuse box cover (dash end cap driver's side)
  2. Two bolts alongside fuse holders removed
  3. Two bolts under the knee bolster removed.
  4. Pulled the knee bolster out at the top and it dropped down.
  5. PO had connected to ign +ve at the OBD plug and a chassis earth. So I used what he had done but plugged my phone lead into his.
  6. Cut his mini usb cable off above the dash and pulled it all out from the fuse box.
  7. Tested and working so reassembled.
Only took 20 minutes and some of that was down to chatty neighbours.
Then I had a brainwave, OK yes it did hurt. I'm sure I used to have ELSA Win on an old PC that I threw away so had a rummage. Found the CDs and the paperwork. Another £30 wasted. Never mind My lad can put that one on his PC.
