Old 24th August 2019, 02:02 PM
Default Not looking good
Old 24th August 2019, 02:03 PM
Old 24th August 2019, 02:05 PM
Unless it's "just" the F125 switch.....
Old 24th August 2019, 02:23 PM
Argh That's usually something slipping, and that is usually the front broken off the front clutch drum.
Assuming you don't fancy a full rebuild, replacing the clutch drum is DIY'able if you're able to get the gearbox out. Its available new from ZF dealers, or you could use a donor gearbox, although that's a risk that it also has a cracked drum. Prestige have a dead one in at the moment I think, although I don't recall what the fault was.
Old 24th August 2019, 03:13 PM
Problem appears to be with 1st gear. Moving off it makes a jolt and switches to 5th. If I manage to manually switch to 2nd before fault occurs it works fine until goes in 1st again.
Old 24th August 2019, 04:22 PM
Any idea what the solenoid current should be? Most are 0.144A but one is 0.742A?
Also strange that fault code says Gear 3 but problem seem to be with 1st.
Old 24th August 2019, 04:41 PM
Unfortunately no time and no facilities to DIY it if the box need to come off, and not worth paying someone else to do it as car when working was worth £1k at most. I did replace clutch and flywheel on A6 on the drive but car was just high enough to disconnect the box not to actually remove it from under car.
Unless it's a solenoid or something else I can DIY from under the car without removing the box I am afraid it will be the end of S8.
Old 24th August 2019, 05:19 PM
This is what Elsa say
ID:	22099   Click image for larger version
Old 24th August 2019, 05:23 PM
As soon as I move off, jolt and fault code registered for gear 3 when it's only been in 1st, if I manage to get to 2nd all other gears work fine including 3rd until it selects 1st again.
Old 26th August 2019, 07:41 PM
Ffs ainars, must be save able on a shoe string.
Just out of interest what happens when the 4 speed is coupled to the S?
