D3 - Body and Exterior Bumpers, bonnets, glass, trims - Everything outside |
In my experience with fully working door handles the car doesn't unlock when you walk by, it only unlocks when I put my fingers under the door handle.
This is not pulling the handle, it sense proximity. If you need to pull the handle its not working as intended and if it unlocks as you approach the car i'd say that it thinks your fingers are below the handle, also not good.
Del ![]() |
I would agree that the sensor thinks something (the OP) are touching the handle and so unlocks when near by
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
I have a D4 and that is how mine works.
The D3 and D4 should function exactly three same, but three D4 improved the handle design as the "sensor" is a separate part, meaning when it goes faulty it can be fixed for about a tenner and boot need ant paint. Sadly in three D3, it gets expensive...
My car "wakes up" (you can hear the Bose amp fan in the boot start up)
when you walk by the handle with the key, But the car won't unlock until you put a hand under the handle. The lock buttons fail often but the button has only one moving part. I have found these handles can be reanimated if you unplug them, and clean the plug and handle contacts with contact cleaner. Water gets into the plug, and screws with the very small electrical resistance range the handle uses to work. Under the rubber button is just a spring and a metal plate the touches a contact on the handle body. Mike
04 A8 - 4.2 Sport Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension Auto Boot - Double Glazing - AMI - Solar roof TV - Bose - Voice Control - TPMS - AFS- TINT Power Blind, Fingerprint - Light package (in and out) Retrofits: OEM Auto headlights & rain sensing wipers OEM Bluetooth phone Bluetooth Audio Streaming Reverse Camera OEM Aluminium Package Auto boot close using remote/door button |
