Old 21st November 2019, 08:09 PM
Ronin Ronin is offline
Default Any tips on doing timing belt on a 2.8 32V?
Hi I need to do the timing belt on my 2002 2.8Q
I know that its a good idea to also do the water pump and make sure its rotor is a metal one and not plastic. I will be also replacing the thermostat. The belt kit itself will be INA brand.
Is there any thing else I should be looking at?
Do any of you know any decent places in Wales to get it done?
Old 21st November 2019, 08:37 PM
I'd recommend a genuine water pump - they're only £80 or so, and they come with a new gasket.
A genuine thermostat is about £25, although this time doesn't come with the o-ring so don't forget that.
You'll need a vacuum coolant filling system to bleed it properly afterwards as the V6 won't bleed itself like the V8 does.
Old 22nd November 2019, 07:55 PM
How much would it cost to do it through you?
Old 22nd November 2019, 10:19 PM
I'm not taking on any customer work at the moment.
Hopefully someone will be able to make a recommendation in your area though
Old 27th November 2019, 05:18 PM
Are you sure? I would be looking at January to do it anyway
Old 8th December 2019, 08:12 PM
I just had a quote for £1000 to replace the timing belt with thermostat, all the tensioners, aux belt and its tensioner, water pump and the crank seal inc of VAT, do you reckon thats a fair price?
Old 8th December 2019, 09:28 PM
Sit down, Waldo Sit down, Waldo is offline
I've just had all that done on a 2001 S8 at a cost of £1457.76.
Old 8th December 2019, 09:36 PM
ouch! was that at the dealer or something?
Old 8th December 2019, 10:05 PM
Local indy garage. About what I'd bargained for tbh.
Old 8th December 2019, 10:25 PM
More time / cost for a V8 maybe?
Unfortunately I'm not sufficiently skilled to do much of the work myself.
