Go Back   A8 Parts Forum > Our Other Audi Friends > A6/S6/RS6 C6
A6/S6/RS6 C6 2004-2011
Old 17th November 2019, 09:52 AM
roberto's Avatar
roberto roberto is offline
Default A6 3.0 tdi my track car issues Help please !
ok,
so i blew the turbo Yes it broke in half and tried to get out of the side
right mess
ive bought a 2nd hand turbo in good condition
fitted it using my own actuator
car sounds good but is showing a fault
my scanner shows this...........
13128
Activation turbocharger control module 1-J724
Electrical malfunction in circuit-sporadic 005-No or incorrect basic setting/adaptation
found this on YouTube = Help !
https://www.youtube.com/watch?v=x7FnVxTEH3Q
Old 17th November 2019, 10:56 AM
Have you tried basic settings in VCDS? The ECU ought to be able to do it rather than having some dododad connected directly to the actuator. IIRC the actuator is driven by canbus which is why said youtube doodad appears to be working.
Old 17th November 2019, 11:07 AM
roberto's Avatar
hi,MJ, i havent got vcds
a mate has thou , hes just got the whole shabang (is that a real word)
anyway hes still learning, and im thick !
OOOH and it revs up good then the tick over is going up and down 500-1500 revs non stop brum brum brum brum
switch off its ok again till revved up then same
Old 17th November 2019, 11:12 AM
homer simpson's Avatar
I think every VAG owner should have VCDS, it soon pays for itself even if just used for scanning and clearing codes. Good luck sorting it. As MJ said, basic settings may sort it.
Old 17th November 2019, 11:14 AM
roberto's Avatar
Default cheers
ill give my mate a call
Old 24th November 2019, 12:15 PM
roberto's Avatar
ok, my mate came up with his new vag-com set up
hes a clever little devil too
all sorted , car runs fine No warning lights etc Revs as it should...
chuffed
Old 24th November 2019, 03:26 PM
Excellent
Old 27th November 2019, 09:49 PM
roberto's Avatar
been out for a test drive
eml on
limp mode
crap
ign off - on ran fine again
then scanned same fault showing but revs well
gutted
mates comin up again sat
Old 14th January 2020, 04:32 AM
roberto's Avatar
well it turned out to be a faulty turbo as it was 2nd hand and worn out and cheap so my fault......
So fitted a new recon one and its runs sweet and fast now no problems
Cant wait for next track days
