Old 5th December 2019, 12:23 AM
Had a.knocking rattle on mine a few years ago and it turned out the be top suspension mounts worn and knocking against metal sometimes. That's the mounts at the top of the uprights where it comes through into the top of the front arch / wing. Replaced the mounts.and all noises went!
Thanks AM8tey - where are these mounts? The top of the strut is a machined aluminium casting with three hollow centring 'spikes' that bolts with three large bolts onto the space frame/turret. If you meant this casting on the strut then it was replaced with the new strut assembly - or is there something up in the wheelarch?
