Old 14th October 2010, 07:35 AM
GlynH GlynH is offline
They are talking bollox. Camber on the front can not be adjusted. Did your 8 come with 20" wheels from new?
Adjusting toe as Dezzy says will reduce the effect a bit.
Once again not guarantees!!!!!!!!
Thanks again Mike...my Mum always said I was special but I have come to the conclusion that you are even more special than me!
I hear what you say Mike but they did not mention camber specifically, use a Beissbarth computerised 4WD alignment system and specialize in VAG Group vehicles with particular to TT, S4/6, RS4/6 & R8 and I have confidence in these guys.
The car originally had 18" wheels and was originally 4WD aligned on those before changing shortly after to the genuine (but refurbed) Audi 20" alloys shod with brand new Michelins if that might make a difference?
I had already replaced one pair of front tyres due to the steel being exposed at the inside of the tread while having the rest of the tread looking like new!
I replaced those at a cost of £547 (and have just been quoted £598 locally for another pair...can anyone recommend another supplier who might be better on price but who more importantly is capable of doing a good job?) but when I went back to get the car 4WD aligned they were unable to adjust anything due to something 'spinning round' and recommended replacing what I took to be control arms?
<wishing I had taken more notice at the time>
Strangely the later tyres don't seem to have worn as bad...
ISTR seeing that 8's were particularly heavy on front suspension and it is common to have to replace some components...I assumed these were the items referred to but I do need to check it out...
WHile i was shopping for parts I thought I would add these to my list...
Thanks again Mike...much appreciated.
Kind regards,
-=Glyn=-
Old 14th October 2010, 09:42 PM
Just found a picture of the tyre before last
Regards,
-=Glyn=-
Last edited by Conan_the_Librarian; 15th October 2010 at 07:45 AM. Reason: embed photo
Old 15th October 2010, 07:48 AM
I notice the 'C' link for the Anti Roll bar is on the wrong way round. Should be behind the control arm. Maybe?
Old 15th October 2010, 09:34 AM
Well spotted mike - that might well be causing the problem
Nothing gets past the librarian!!!
Old 15th October 2010, 10:27 PM
Bloody hell...how do you guys spot things like that?
But it is behind the control arm in the picture isn't it...it looks like it is the drawing is showing it in front to my eyes.
Then again I may have had a drink...
Well the car is going into Ben a week on Monday for some TLC so maybe he could act as judge & jury?
Hawkeye THE Librarian.
Sounds kinda special doesn't it?
Thanks & kind regards,
-=Glyn=-
Old 16th October 2010, 09:45 AM
Ooopps my bad. Just spotted that the photo is taken from the rear. That being the case then the 'C' link is correct.
Old 16th October 2010, 10:03 AM
Are they?
I took the damn things and even I don't know!
Kind regards,
-=Glyn=-
