£900, wow! I didn't expect that. Well that is a real shame. I had almost convinced myself to get one done this summer and was actually looking forward to seeing how it turns out.
It's still cheaper than getting hold of a new one (rear) but that's a big chunk of cash. I was kind of thinking £400 or so. Guess it just shows I know nothing about galvanising.
Does Cadmium plating still exist? Extremely toxic isn't it?
We used to get blokes asking for "Cad plated" bolts when I worked in that industry. What that usually meant was bright Zinc plate. But sometimes they specifically wanted yellow Zinc. There was a belief it was a better coating. I was never sure if it was due to being fractionally thicker, or less reactive with the additional chemical treatment to turn it yellow, or whether it was just the placebo effect?
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived ![]() Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
Galvo process is a caustic bath, rinse, pickle, rinse, flux, galvo dip.
From memory the zink bath is around 500c We know the areas they tend to go, and as they seam to rot from the inside out we can repair these before going to dipping to help prevent and distortion where it might be a bit thin. And £1000 yeah right oh. We get charged on weight, A farm gate is heavier than a subframe and you can buy one of those for about 200 quid brand new, galvanised.
1996 A8 4.2 QS. Bose, Solar roof, um...um... rally sport towbar. Now gone to a new home as the Traders 8. Bright yellow bus o love. Last edited by Dezzy; 10th January 2020 at 08:33 AM. |
On its own cadmium plated components are light gray and you passivate them in chrome which causes them to go yellow. A 10um coating can whitstand 10 000 hours in a 60C salt bath which translates to many many years of normal use in a car without any corrosion as long as there's no mechanical damage to the coating. Here are some pics of the jag parts before and during plating. Once again this was a one off favour for the company i used to work bosses mate: ![]() ![]() |
I've spoken to another hot dip galvanising company who said they would not do the subframes as the holes in them are too small to allow for air to escape as soon as they are dipped in the 450-500C vat which would cause an explosion or deformation.
They also said the best course of action is to sand blast it then get it powder coated to a rough finish and then paint it with some proper boat paint for best result. They also said that its the temperature shock which can warp and cause the subframes to crack and that ovens that poweder coats use heat up gradually to completley avoid this risk... so it looks like a no go unless someone else has a better idea? |
The holes issue is not a problem as long as there is a hole. I use a 6mm dia hole in 42.2 o/d heavy tube ships hand rails, drilled on the underside of tube right where its welded to the last stanchion. That hole is big enough to let the air escape as it expands. So the big holes in the subframe will be fine. Distortion however is another thing all together and I don't know how you'd control it. Still think a basic steel jig to check after, it would be interesting to try one. You can buy brnd new glavo chassis for a land rover be interesting to know how they manage it. Marine paints need a full application to work, I have Jotun primer I use at home. It's thick and needs thinning to use, also goes off quick throw the brush away job. It's a zink rich primer and I rate it. Pop round with a jam jar or 2 and I'll fill them for you. Top coats are all different, under the waterline ships use an antifouling paint, that would useless to you. Above waterline it rots fast, anyone that has been to sea on a ship will all say the same, its a constant battle. International, hempel, jotun all do good emamel topcoats but I really don't think it'll help the rotting from inside out. Do what they do with Land rover chassis, waste oil and diesel mixed.
