Its weird - the D2 sensor was around for four years before the 4B C5 arrived but somehow has a 4B number despite only being used in a 4D chassis.
The C5 sensor (4B0907659A) turns up in 1998 and is fitted to everything until 2008 that isn't the D2, including the D3. |
That is indeed very weird part numbering, especially with the A version following the B version by several years...
![]() I need to take 4 screws out, which also hold the ECU box lid down. The middle 2 are fine but the outer one (by the pipes) has been damaged so a normal screwdriver will not grip. And the inboard one just turns (not easily) without lifting so I suspect the metal insert it screws into is rotating in the plastic moulding. It's much more important to keep my ECU box sealed and dry so I'm staying out of there for now. ![]()
For now I'm very tempted to just cut the trim so that I don't need to undo the recalcitrant screw, but in the longer run it ought to be undone and fixed "properly"
Did you find it OK? See attached picture:
Depending on how badly corroded the screws are, sometimes they can be loosened using mole grips on the insert once the lid is off. Worst case drill the heads off. I replace the factory inserts with M5 D nuts like these and fit new screws. |
I did. I don't know how I missed that button in nearly 10 years of owning the car!
I guess I just saw the recirculate symbol and never really noticed the 'A'. I tried it briefly last night (on a 1 hour round-trip to see Sandi Toksvig at The Lowry, which was rather funny and enjoyable I must say ![]() As I set off, I noticed the button wouldn't stay lit/active. It seems that this was because I was using the windscreen demister at the time. Once I turned that off, the auto-recirculate remained active for the whole journey. So I assume it's working as it should, even though there seems to be no indication that it's actually doing anything!
![]() Found them on Screwfix, though these are M6 not M5 if that matters: https://www.screwfix.com/p/insert-nu...-50-pack/59937
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 13th January 2020 at 05:41 PM. |
M6 are too big - there isn't enough plastic in the box to hold them. There are plenty of M5 versions on ebay. I drill the original holes out to 8mm before fitting them. If you're replacing the screws I'd go for something 5mm longer than the originals as the threads are recessed in to the D nuts slightly. The original screws will just catch, except where the HVAC sensor is - you definitely need a longer one there.
Wonderful advice, many thanks. You've been there, done that and are an invaluable fount of knowledge.
