The aerial is within the rear window lines, the odd ones at the top. There is an amplifier above that too. DAB is the UK is garbage apart from in cities, it was designed by BBC anorak radio ham fanatics rather than by a commercial operator who wanted it to work well and be future proof we were early adopters of DAB and ended up with an over-budget, underpeforming infrastructure with low qaulity streams (due to the codec) (just about everwhere else in the world uses the more robust and much higher quality DAB+).
I think it looks like I will have to put up with it as it is. Thanks though
Audi A8 2005 D3 3.0 Tdi quattro in Aurora Blue with cream sports seats, DAB Bose sound, 19” five spoke alloys, fingerprint technology and SatNav, wooden sports wheel and gearchange knob |
The A8 should alternate between FM and DAB too, if it isn't maybe it needs tuning and the stations storing. I guest there must have been some technological improvements over the years.
There has, to be honest the D3 DAB was hit and miss. The D4 reception was better, places that the D3 would cut out or switch to FM the D4 worked.
My Q7 is better again, and supports DAB+, which most of the stations I listen to are now broadcast on! So probably not a fault I'm afraid, just the way it is.... |
Was dab fitted at the factory in 2005, I know my 2006 doesn't have it.
Just thinking if the dab tuner was retro fitted the Ariel and system may not be optimised for dab..... Maybe????
I retrofitted DAB on mine, didn't need to tell the car anything. It spotted the tuner in the MOST loop and added the relevant menu option automatically. Reception was no different to any of the other cars I have with factory DAB. I did add the coding later on but it made no different operationally.
