If you look at the design you can see why, it's not a "typical" bladed fan that could indeed run backwards, it's basically a centrifugal pump with vanes in the cylinder that "catch" the air and make it more efficient.
Running backwards it's still a centrifugal pump but the vanes make it extremely inefficient. And I expect the geometry of the air intake and outlet ducts contribute to making air only flow one way.
As my fan has been playing up for ages now (nearly 3 years on and off, see: http://forum.a8parts.co.uk/showthread.php?t=13248 ) I've ordered one of these (from Poland!).
They're a Chinese copy obviously but I'll keep the original anyway and see if it can be refurbished. I might also look at constructing an "adapter" for the lead, rather than cutting the plug off the old one. Though it might be possible to just disassemble the plug if the contacts at the end of the wires are the same design. ![]()
-Andrew 1967 Bus 1980 Rabbit Pickup 1992 Corrado 2001 S8 2010 Jetta TDI Cup Edition |
IIRC the connectors are all fairly accessible with the bonnet open so I should be able to test any adapter quite easily before fitting and make sure it's spinning the right way. ![]()
Suppose it’s too optimistic to assume d3 wipers would fit the d2 as well? because that would solve a whole heap of spare parts issue
PF late '97 D2 2.8 Aluminium Silver. Solar roof, Full Heated Leather, Double Glazing, 17" wheels, Sports Steering Wheel, Cruise, Blinds, Bose sound. ![]() Fiat Tipo diseasel econobox with all the buttons and none of the soul that now does all the heavy lifting. Ford Capri Laser: noisy, slow, thirsty, bouncy, no buttons but it always sounds like it’s REALLY trying and I can’t help but chuckle when it parps and boings along. And people of a certain age stare at it with a wistful look in their eyes that clearly says…I had one of them. And I sold it because of the kids ![]() |
I'd be shocked if the entire assembly is the same, but it may be that parts of it are the same? There's a D3 at my local junkyard currently. I may go take a look at it again.
Far too optimistic I'm afraid. I think all of it is different, although it may be possible to adapt the motor with some tinkering. I need to take another look at one.
The motor arrived and I’ve managed to get it fitted, it was £65 delivered and a cheap Chinese copy as mentioned but I doubt the car will last much longer so it’s good enough for me. Fits perfect runs quiet and kicks out more air than before, although mine was worn out. will post some pics up when i get chance
![]() ![]() Quote:
However the male/female setup seems to be reversed, the D2 fan is male whereas the D3 is female, so you couldn't disassemble and reinsert the wires into a different shell even if they were compatible.
As it's spade connectors, makes for a pretty easy wiring job.
Either cut and shut a pigtail cut from your old fan, or from a wreckers yard (anything Audi (or VW?) from that era has the same style connectors) or Cut the plug off one end (fan is most appropriate) and put some standard crimp type spade connectors on the ends and plug in manually (I use brass spade connectors with a proper crimping tool, but the common red or blue crush type will work ok) or Make a short double-ended female piggy-back lead and leave both plugs intact.
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived ![]() Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) Last edited by 27litres; 2nd February 2020 at 11:15 AM. |
