Old 27th January 2020, 09:58 AM
Hurrah!
Old 27th January 2020, 10:17 AM
Excellent.
I just found this comment about measuring blocks in the online VCDS-Lite manual (https://www.ross-tech.com/vcds-lite/...sblocks.html):
Shareware Limitation(s): • You can only view groups 001-025. Groups 000 and 026-255 are blocked
So maybe you can't actually look at the brake switch measurements in group 66 using a third-party cable?
(I used to have VCDS-Lite but it was a fully-registered version that I paid for, so had fewer limitations.)
Old 27th January 2020, 07:39 PM
hunker7 hunker7 is offline
I should probably spend $99 on the "home mechanic" version as let's be honest here, I'm not driving anything else but Audis
Old 28th January 2020, 08:49 AM
C4R 100N's Avatar
C4R 100N C4R 100N is offline
Anybody tried VWtool? It should work with D2's at least.
vwtool.zip
1998 D2 S8 Jaspis Green
