Old 12th February 2020, 12:22 PM
Versace Versace is offline
The car is a 2004. It seems like it was replaced at Audi, as everything looks so original, the connector with the resistor has an Audi sticker on it And an LED lamp inside...
But the engine runs seamles, smooth and no vibrations.
I will replace them anyway but they are so expensive
We have found the other cable too!
S8 D3 FL II.
Porsche Cayenne 958 Turbo
BMW E83 X3 3.0d M-Sport
Old 1st March 2020, 06:41 PM
Joe2.0E Joe2.0E is offline
I had an 04 D3 and from memory these hydraulic mounts failed when the car was about 6 years old. (Failed meaning they threw an error code on diagnostics when car was scanned. As they were crazy money and could only be got new at the time, I decided against replacing at the time.
I then kept the car for several more years and never had any issue with vibration or similar. I’d leave them to be honest.
Old 1st March 2020, 08:19 PM
Don't get used ones as they will also be faulty. New ones are probably a waste of money as they will probably only last a couple of years. My first failed at 3.5 years and don't forget these new parts have been sat on a shelf deteriorating for 10+ years.
Old 6th March 2020, 04:45 AM
27litres's Avatar
27litres 27litres is offline
The FL D2's have similar mounts.
As they're hydraulic, I just thought the electrics were a sensor for when the mount failed?
I didn't think they were or are in any way "active"...
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 6th March 2020, 07:20 AM
The electrical connection is for a solenoid which controls a valve to an air pocket inside the mount. The ECU controls the effective strength of the mount by switching on / off what is basically an air spring. There's an SSP on them somewhere - I'll see if I can find it.
The D4 actually has a separate computer just to control the active engine mounts
Old 10th March 2020, 03:42 PM
Here's Audis take on the D4 4.0T Tfsi Active Engine Mounts :
Active engine mounts: counteracting vibration for greater refinement
Audi normally uses firm, sporty settings for its engine mounts. For many years now certain models – notably the A8 at the top end of the range – and various engines have had switchable electromagnetic mounts. These have two operating settings: at idle speed they have a “soft” characteristic to prevent noise and vibration from reaching the interior, but when the car is being driven a firmer damping rate is selected in order to suppress engine vibration.
The active engine mounting that Audi has developed for the 4.0 TFSI takes this technology a decisive step further – it cancels out engine vibrations with out-of-phase counter-oscillations. The key component is an electromagnetic oscillating-coil actuator. This has a rapid stroke that is transmitted via a flexible diaphragm to the hydraulic fluid in the mounting, which also absorbs oscillating movements from the engine. In the fluid these are overlaid by the actuator movements and cancelled out.
The control units for the active engine mounts receive their signals from two sources. Engine speed is detected by the crankshaft sensor; these signals are used to compute the precise phase and frequency of the actuator signal. Acceleration sensors on the two engine mounts supply the data that determine the amplitude necessary to cancel out the vibration.
When the new 4.0 TFSI is running in the four-cylinder mode, it generates a certain amount of engine vibration and drumming noise of what is known as the second order. They are not typical of a V8, but the counter-vibration generated by the active mounts reduces them to an undetectable level.
At idle speed with all eight cylinders in operation, engine excitation of the fourth order occurs. This too is largely eliminated by the active engine mounts so that the engine appears to be running even more smoothly.
Old 26th March 2020, 01:00 AM
How exacty does this work??
S8 D3 FL II.
