And possibly just the old pump seating/sealing issue.
In which case, how much fuel is in the tank? If it's less than half full, might be worth adding a gallon or two to see if it runs. I could be wrong but I think you should be able to hear the fuel pump run (briefly) when you turn the ignition on. Might need to stick your head in the boot to hear it, while someone turns the ignition on for you.
![]() ![]() The petrol tank is full minus 60km. Is there somewhere under the hood that I can unbolt to check for fuel? Can I spray something somewhere to simulate fuel delivery? Thanks again for everyone's help. Is that easy to check or inspect visually?
1998 D2 S8 Jaspis Green Last edited by C4R 100N; 28th February 2020 at 08:41 AM. |
If you enjoy lying in the boot, contorted and getting high on petrol fumes, it's a wonderful job. Otherwise it's a bloody awful job to do.
![]() It's easy to determine if that's the problem though ... just put a few more gallons of fuel in. And if that does turn out to be the problem, the workaround is to keep half a tank or more of fuel in the car at all times. I drove mine like that for a few years. It can be fixed but I think there's probably a knack to it. After a few failed attempts (by myself and 2 different mechanics) I just gave up and replaced the entire tank.
I have also read that I can squirt starting fluid somewhere and possibly get the car to start, so that would be a bonus right now. Another thing that I have just read is that I can reverse the electrical connection at the terminals on the fuel pump to make it run backwards for a second or two, and that *may* unjam the pump, should the failure be due to a certain commutator problem. Quote:
1998 D2 S8 Jaspis Green |
New fuel pump is slightly more buzzy than before and you should be able to hear it prime when turning the key to ignition on. Hope you get your problem sorted.
So extremely unlikely it's the seating problem.
![]() (Unless that 60km involved the most aggressive driving imaginable! ![]()
![]() ![]() Thanks for discounting the seating problem for me. I promise that I was only driving aggressively just the once up a lovely twisty hill for no more than 30 seconds! Otherwise, sedate city driving in traffic I am afraid.
I don't know, I'm sure I could use up half a tank in 60km if I tried ![]()
Just to add some background info:
Mine was a combination of two isssues, namely fuel pump failure and then the subsequent problem of 'running out of fuel' when the gauge shows a quarter full. Once the fuel pump was replaced, and having effectively run out of petrol, the car showed signs of attempting to start on a couple of occasions and then pretty much nothing else. Strong cranking from the battery/starter motor. Low-loaded back to the garage to check (I was convinced there was fuel in there) and then discovered thanks to this forum about the fuel tank issue where part of the system to maintain equal levels on both sides of the fuel tank isn't working properly in my case. MJ seems to think it's one of the fuel return pipes possibly being blocked. When my fuel pump borked, there were no prior warning signs apart from the car not moving lol, just a couple of spurts forward before the car stalled in the middle of a nicely-painted diagonal striped box junction. Good luck with your investigations. It's probably worth updating your profile/signature to reflect where you are geographically, as someone on the forum may be able to assist with a quick VAGCOM or OBDEleven unit.
![]() Marty! You visiting Newcastle, NSW anytime soon? If so, bring your Vag Com cable and working laptop please!
1998 D2 S8 Jaspis Green Last edited by C4R 100N; 28th February 2020 at 12:12 PM. Reason: Marty not Matty, doh! |
