Old 14th March 2020, 04:43 PM
Audifan Audifan is offline
Default Floor switch?
What is the round switch on the floor under the gas pedal?
Old 14th March 2020, 04:46 PM
It's the kickdown switch, which may or may not be enabled.
More info here:
http://forum.a8parts.co.uk/showthread.php?t=50
Old 14th March 2020, 04:47 PM
gninnam gninnam is offline
Kick down I believe.
When the 'gas' pedal' is pushed all the way down and hits the button it drops down a gear
Beat me by 30 secs!!
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 14th March 2020, 04:50 PM
Not that useful on a manual swap. Use it for nitrous Or exhaust cutouts?
Old 14th March 2020, 07:24 PM
Thanks guys. Good thing my car doesn't need it anymore. I had troubles with removing the big plastic base when I had to remove the side transmission tunnel panel to check the orange drains. I accidentally broke the switch and never got around of fixing it as it didn't affect driving the car or turn on any warning lights.
Old 15th March 2020, 01:07 PM
Stromaluski's Avatar
I had no idea there was a switch integrated into the pedal stop...
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
Old 15th March 2020, 01:20 PM
I reread parts of that other thread and noted the very very simple "check" procedure, and it works!
1. Get into car. DO NOT insert key or turn ignition on!
2. Check gear selector is still in P. Turn sidelights on, look at illuminated +/- symbols on gear surround.
3. Press accelerator pedal to the floor, those +/- symbols get brighter (and you should hear the switch click)
Simples!
Old 15th March 2020, 02:14 PM
Haha so it does!
Old 4th February 2024, 03:59 PM
christhompson's Avatar
Very late to this thread. BUT teehee haha. Yes it does work
Old 5th February 2024, 11:29 AM
It's good to repeat this procedure from time to time as it's fairly easy to inadvertently switch the kickdown off (I've done it).
Without it enabled the cars lifeless and flat, and this switch is easily overlooked.
