Old 15th March 2020, 04:43 PM
RS6's Avatar
RS6 RS6 is offline
many thanks Adrian for your help
I will order those as a replacement
The garage mentioned when they tried to remove them they had to remove the whole head light lense and were worried about breaking the headlight does that sound like something that has to be done when fitting these bulbs maybe an access issue?
I have never really looked at the headlight in great detail
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
Old 15th March 2020, 05:20 PM
I got a different design that work well and didn't need any cutting/drilling. Documented somewhere but I can't easily find it.
However, if you've already got larger apertures it's much easier.
No particular problems fitting them though...……….. Maybe your garage doesn't know how to access the bulbholders?
(IIRC they just pull out, but maybe with a larger aperture that's changed?)
Old 15th March 2020, 05:35 PM
This is my 2013! post when I replaced the sidelights - still working!
http://forum.a8parts.co.uk/showpost....5&postcount=61 It will show you what my bulbs look like, though no longer on eBay of course.
And this is what they (still) look like lit. http://forum.a8parts.co.uk/showpost....9&postcount=13
Old 15th March 2020, 08:12 PM
As per the thread I made, the modification to the inner lens is needed to allow them to be drawn out from the back. It is just a light Dremel so the garage may be happy to do, based on the info in the link?
I didn't fancy having to take the lens off to change a bulb, but then being LEDs they shouldn't need doing very often!
Andrew's would be the less hassle option, if you don't mind the design
Old 15th March 2020, 08:28 PM
These look the right size: https://www.ebay.co.uk/itm/H6W-SLIM-...s/263174382789
(Might even buy a couple myself...)
Old 15th March 2020, 11:23 PM
It's a shame reputable brands don't do H6W. For the PF D2among other cars I found no name LED does not last long, kept changing 1-2 times per year. I have since used Osram and Philips and have not needed to change them.
Example https://www.amazon.co.uk/dp/B00OYT13..._IDSBEb0TCY2WJ
Don't know why they would do W5W and not H6W. Maybe there is an adaptor you could use.
Old 24th March 2020, 07:52 PM
RS6's Avatar
RS6 RS6 is offline
Just an update i ordered those side light bulbs and they have turned up but they are tiny in comparison to what was fitted before
still no clues as to what type of side bulb was fitted before? they were much much bigger
