Old 19th March 2020, 09:26 AM
Versace Versace is offline
Have you tried it on some perfectly flat ground? Maybe a wheel is in a dip oron a lump or maybe the ground is just curved but looks flat.
Are you kidding me?
Ofcourse it’s on a perfectly flat surface.
S8 D3 FL II.
Porsche Cayenne 958 Turbo
BMW E83 X3 3.0d M-Sport
Old 20th March 2020, 05:02 PM
IT D3 IT D3 is offline
How are you calibrating it? Using default values or are you actually measuring it yourself and entering the values.
Ground has to be super flat for calibration and you must not be in the car for the process.
Old 23rd March 2020, 07:29 PM
I'm measuring and entering the actual numbers.
I did it at least 20 times and walla, now It's standing proud.
Rear L-R is 3mm difference, front is 1mm. I think this is good enough.
S8 D3 FL II.
Old 26th March 2020, 01:02 AM
Today once again, front LEFT 425mm, front RIGHT 420mm...
Rear is inside a 4mm tollerance...
S8 D3 FL II.
Old 31st March 2020, 09:16 PM
To be clear, are you saying the tolerances between the two fronts is increasing?
