D2 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
Thats a crimp clamp the same as CV boots use, not a clic-R. It needs a slightly more specialist tool, but a worm-drive hose clamp will work fine.
A smear of engine oil or petroleum jelly will work on the o-ring. The large seal for the top of the tank should have a lip at the top, like an upside-down top hat. Oh, the plastic pipe is the return I think, which should just be tucked in to the fuel pump housing. (edit - don't use petroleum jelly on rubber. That was terrible advice and is retracted!) Last edited by MikkiJayne; 9th November 2020 at 09:54 AM. |
Glad to be corrected by a real expert.
![]() At least I only said "looks like". ![]()
I feel like a idiot
The hardware store that I went to didn't have them in stock and was told it'll be 2 - 3 to get them in. So I didn't order them as they are closed on the weekend and they are closed when I get back in town from work when it would come in if I had them order it. I just ordered them online instead. So I'll have to wait some more before I can finish this fuel pump job.
https://smile.amazon.com/Dow-Corning...1718112&sr=8-6
-Andrew 1967 Bus 1980 Rabbit Pickup 1992 Corrado 2001 S8 2010 Jetta TDI Cup Edition |
I wouldn't want to put silicone anywhere near the fuel system, and especially not inside the tank. It will do bad things to the O2 sensors amongst other things. Something fuel-soluble is best in this application
Good thought! I hadn't even considered that.
Is engine oil really safe to use in fuel-soluble application? I've heard that using petroleum jelly can become a problem with rubber o-rings?
I would use oil since oil and fuel are basically the same thing. A tiny smear of oil on the o-ring will safely dissolve in to the fuel and be burnt off in normal combustion.
Say a fingertip of oil on the o-ring is 1ml, dissolved in to half a tank of fuel thats a ratio of 50,000:1 which is totally insignificant, similar to what is coming in as vapour from the crankcase breather. |
Ah ok. Thanks for the info.
