Old 29th June 2020, 08:32 PM
Audifan Audifan is offline
I'm trying to figure out what the two bottom crush washers (in this picture below) are for that came in the fuel pump o ring kit. I know the two at the top of the picture is for the banjo bolt but not sure about the other two?
Name:	o rings 3.jpg
Last edited by Audifan; 9th November 2020 at 09:57 PM. Reason: switched picture to attachment
Old 29th June 2020, 09:18 PM
Those will probably be for the night heater option - that uses a tiny banjo fitting on top of the long pump retaining bolt.
Old 30th June 2020, 02:19 PM
Stromaluski's Avatar
What is the night heater option?
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
Old 30th June 2020, 02:45 PM
A fuel-powered auxiliary heater which can warm up the car without the engine running. It lives under the air filter box and is plumbed in to the engine coolant circuit. It could be run on a timer or remote control so the car is toasty warm and defrosted on winter mornings.
Old 2nd July 2020, 01:27 PM
Sounds like a nice feature! Is that able to be retrofitted to a car that didn't have it originally?
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
Old 2nd July 2020, 02:26 PM
Anything can be retrofitted if you have a complete donor car. A friend in Germany is doing just that, but its a lot of work.
Aftermarket options are available though which is probably an easier option: https://www.webasto-comfort.com/en-i...arking-heater/
