Old 16th July 2020, 04:48 PM
Ronin Ronin is offline
Default It works!
OK people, I'm glad to confirm that the above BMW valve block is a direct swap with the AUDI one and is a much better and sturdier design, even the mounting tab matches and the threaded clip fits the BMW part too. No modifications required at all, the plug from the loom in the seat fits perfectly too.
You should budget around 4h to do the first seat, 2h after that for the second seat.
There is no special tools required other than a zip slider to zip up and then staple the bottom of the back rest as it was done at the factory.
ID:	23616   Click image for larger version
ID:	23617   Click image for larger version
ID:	23618   Click image for larger version
ID:	23619   Click image for larger version
Old 16th July 2020, 06:34 PM
Wow, nice find
Old 16th July 2020, 10:07 PM
That's amazing, many thanks. I think we need step-by-step explanations on that if you can do it please! It looks very scary to an amateur.
Old 17th July 2020, 07:22 AM
Ditto
Old 17th July 2020, 07:25 AM
Great find, thanks for sharing
Old 17th July 2020, 07:27 AM
Haha I'm an amateur too!
I've ordered a set of assorted zips from amazon for 5.99. They should be here today for me to try. If i cant get it to work Ill just sew it all together.
I will try and make a guide, maybe a step by step start to finish one of on the drivers seat.
Old 17th July 2020, 01:40 PM
That is, indeed, a great discovery. I suspect very many of us suffer from the same problem and have been too intimidated by the work and parts availability to attempt a fix.
Old 18th July 2020, 09:06 AM
Could you supply part numbers please and if possible some sources of supply at "reasonable" prices - was yours new, used or a "clone"?
Old 18th July 2020, 09:20 AM
Loads on ebay if you search for 'bmw e38 lumbar valve'
Old 18th July 2020, 09:26 AM
Thanks MJ.
The genuine Audi brand new one I have (4D0959931) came from the US, the supplier still has some and they're about US$80 each. Can't recall what I paid back when I got mine but the final price with shipping and import duty works out now to just over £100 to a UK address.
