Old 18th July 2020, 09:06 PM
Ronin Ronin is offline
Ah, thanks, yes I've seen those zips with the backrest right back. Does that then allow the centre section to lift up out of the way to access the bladders etc.?
It will allow you to peel off the center section which will expose the 2 air bags and then lift up one of the bolsters.
The air pump and valve block are on the passenger side bolster.
You can just trace the pipes coming out of air bags to find them.
the bolster is held down with a long wire thats attached to the metal base of the backrest.
You will need a flathead to bend up the tabs that hold it down.
It looks scary but trust me once you do it its easy it just looks hard. If you do decide to do it i can help you over whatsapp etc.
Also i would advise to disconnect the battery as there is an airbag in the seat.
