Old 31st October 2010, 11:48 AM
deromas
Guest
Posts: n/a
Default light internal - relay 382 - 4d0 907 131 - 4d0907131
translated by google ... sorry if it is not perfect.
Hello everyone. I'm fitting a burglar alarm on my a8 d2 4.2 of 1994 (bought in June .... in very poor condition).
I have already solved the problem of dual control pulse to open the doors ( from blinker connect the normally open contact to the opening doors of relay and to cascade another relay that goes to control the contact opening).
now I have to connect the signal indicating the open door. I wanted to use the relay "4d0 907 131 A" number .382... but where is it located? I can not find ... Thank you all for the information ....
Old 31st October 2010, 12:06 PM
It should be if the electric cabinet in the passenger foot-well on the upper rack of relays.
Old 2nd November 2010, 10:34 PM
deromas
Guest
Posts: n/a
I also thought it was placed there. I had even tried them before asking for help. but not find it
help
Old 4th November 2010, 01:29 PM
deromas
Guest
Posts: n/a
in that position is:
204
205
267
297
301
356
361
my problem is the signal of door opening to connect it to a new alarm.
where else can I take? the contacts of the pump automatic closing - alarm?
Old 4th November 2010, 03:14 PM
Sorry deromas but I have not done this before. Hopefully someone else will come along with an answer.
Old 4th November 2010, 05:45 PM
Is it maybe one of the relays above the battery?
Old 11th November 2010, 10:06 PM
deromas
Guest
Posts: n/a
discovered where the relay-module! simply not there.
control of interior lights, timing etc.. and all located in the central locking module located in the back near the antenna!! in the same module is also the alarm. them ... there's lots of good signals including front and rear opening hood and doors ... Currently I can only find the connections .... to connect my new-bought for theft in an economic opening with remote control and the key to flip-
I hope that we can understand ..... translated with google ....
