D3 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
According to Elsa it's 0.4 hours for 3.0 TDI, and 1.3 hours for one sensor on 4.2 or 1.6h for both sensors not including adaptation. Gearbox does not have to come out, you just unbolt subframe and lover gearbox a bit to reach to the sensors, still not something I am looking forward to do on drive. On smaller cars with 2.0TDI it's easily accessible under bonnet, can be done in 5 min.
It reaistically can be done in much less time, by only lowering the gearbox and having thin arms, but in any case the parts were relatively cheap hence I did both at once.
Sadly for Ainars the previous owner of his decided to save a few quid ![]() |
BTW, the 3.0 is the same as the 2.0 - 0.4 hours in Elsa is ~ 5 mins it seems ![]() |
Got the sensors today but the wrong ones.
![]() I just put in part number 07Z906051A when searching for them and ordered the genuine Audi ones that came up for a good price without double checking the number so have bought 079906051A. I can replicate the results on ebay, searching for 07Z bring up both 07Z and 079. Looking at some aftermarket sensors they are listed as compatible with both 079 and 07Z and also 03G. The difference is 1 mounting hole on 079 and 2 holes on 07Z but since aftermarket parts are listed as compatible with both so electrically they should be the same. I am also not sure they are original Audi, they do have part number on but came without any packaging and were a bit cheap for OEM. Not sure what to do now, if they were easily accessible under bonnet I would give them a try but considering the work involved I don't really want to mess around. But not doing them tomorrow would mean to wait till next weekend
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 17th July 2020 at 02:09 PM. |
This is the problem with ebay listings, a lot of sellers put in 'compatible' or similar numbers in their listing specifics to help them gain more exposure. If you are unsure, return them as you don't want to spend all that time and labour for them to be incorrect.
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
I think I will give it a try.
3.0 A6 used 076, 07z and 059 part numbers 3.0 Q7 used 07z and 059, 4.2 Q7 059 A8 3.0 and 4.2 both used 07z I do not need to fully assemble it to test, I can test and see if it brings up fault code and compare readings to the other bank.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 17th July 2020 at 05:06 PM. |
The sensor has dies completely now, no readings at all , stays at 0 mBar. No more DPF error P2002, just P2453 for the sensor. This does not throw up error light and no limp mode / reduction in power. So in a way it's good news, I do not need to rush into changing sensor and could send the wrong ones back and get correct.
I understand if the sensor is not working ECU will start regeneration based on the mileage since last regen instead of readings from the sensor. It's not ideal long term but does not stop using car to full potential in the meantime. The problem is sensor could start partially working again and give the wrong readings causing limp mode. I will have a look under car today anyway and see if I still want to try to change it today or maybe unplug it for now if it's possible with less dismantling and wait with change until I get the right ones.
100% your call, but I ran mine for a couple of weeks, while various dealers tried to work out how to do it, and the symtoms got gradually worse until the "limp mode" was barely able to move the car.
If it does kick in and get to that state, factor in a tow truck! i.e. get breakdown cover if you haven't already ![]() Or just use the S4! |
I had a look last Saturday but opted out of doing it myself
![]() ![]() ![]() So I was back looking for a garage to change sensor but most are not interested, must be too busy. It's booked in for Monday now but they refused just to change the sensor and could not give price, said they need to put it on diagnostics and check themselves first for a fixed cost of 0.5 hours labour and then when they have diagnosed it then they can give price for the fix.
That doesn't sound great, I can understand them wanting to take a look to see what they are getting into, but wanting to charge you to do so isn't great!?
