Old 7th October 2020, 07:16 PM
When you're coasting in neutral the ECU is getting a number of inputs that it's not expecting. With the engine idling and no gear selected the ECU expects the car to be stationary! However it will be getting inputs from the ABS sensors that say it's moving. The output shaft sensors won't match the input shaft sensors. The ECU is confused. When you stop it thinks all is as it should be and you get a steady idle.
