Go Back   A8 Parts Forum > A8 D4 > D4 - Interior Electrics
D4 - Interior Electrics Airbags, Sensors, climate modules, instrument clusters, switches etc
Old 1st November 2020, 05:40 PM
v8quattro42 v8quattro42 is offline
I’m gonna install a Stag 400Dpi with Hana gold injectors and KME R2 Twin reducer till 395KM should be enough. I did install lpg before then I’m sure all gonna be fine. It’s just my first FSI engine that’s only different.
Night vision need to wait a bit as I don’t have air bag for a new steering wheel and I want to install few thinks together. I’m still looking for a new dashboard with head up display cut out. Not many for sale on eBay.
Should be with me next week, the we will see.
I’m not rush as I don’t have a lot of time right now , just weekend for my own.
Old 3rd November 2020, 01:10 AM
H-M3 H-M3 is offline
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 4th November 2020, 12:43 PM
IT D3 IT D3 is offline
that's great to see you're modifying the D4 already!!
As there is a few of us very local we should meet up post lockdown.
We can meet up at beckton triangle/retail park or something near there.
Top work on the retrofits.
I'd be interested to know more about the heated steering wheel retrofit and what's needed exactly.
Also, i remember you car the airbox was damaged?? did you fix that?
Audi A8 D4 2010 4.2 FSI (
B & O + Extended leather + Comfort Seats + quad zone climate control.
Old 4th November 2020, 01:27 PM
http://forum.a8parts.co.uk/showthrea...ghlight=heated
See post 17, hopefully useful
Old 6th November 2020, 12:12 PM
Thank you
Old 12th November 2020, 07:26 AM
Hi guys.
Some small update about my work progress
Then on a first line it’s go a head up display as is quite a lot of work
It was not easy to buy a dashboard for hard up display mounting but it was possible and it cost £300 included delivery. (4H1 857 067B)
Head up display and trim I bought like months ago and cost me £280 (4H0 919 617A) and (4H2 868 061A)
Also we need two plastic brackets, I bought them on Audi device and they cost included screws around £26. (4H2 857 745A and 4H2 857 746A)
10pin connector is necessary to connect that unit to a loom, there is two grand wires, two positive wires na two can wires. (1J0 972 930A)
One think what I did not bought it was a steering column bracket because I did some job on my one. Basically standard one don’t have a attachment for head up display brackets. But is easy to make some by yourself. That’s a correct bracket number (4H2 419 250)
After installation you need to code 5f and 19 address by vcds for head up display
And also make some changes on MMI in green menu.
ID:	24463   Click image for larger version
ID:	24464   Click image for larger version
ID:	24465   Click image for larger version
ID:	24466   Click image for larger version
ID:	24467   Click image for larger version
ID:	24468   Click image for larger version
ID:	24469   Click image for larger version
ID:	24470   Click image for larger version
ID:	24471   Click image for larger version
Old 12th November 2020, 03:14 PM
Dashboard almost finish
ID:	24476   Click image for larger version
ID:	24477   Click image for larger version
ID:	24478   Click image for larger version
ID:	24479   Click image for larger version
Old 12th November 2020, 10:48 PM
BRAVO mate incredible. Scary seeing the dash all stripped, clearly you are fluent at this.
Old 13th November 2020, 10:18 AM
Today I was finish some bits about heated steering wheel.
I was add three extra wires what was a signal cable between switch and a steering module. Also 12v supply for a heated steering wheel for a main plug of steering module.
To finish that I coded 08 module for extra option of steering wheel all rest was already coded.
Currently waiting for a steering airbag
ID:	24489   Click image for larger version
ID:	24490   Click image for larger version
ID:	24491   Click image for larger version
Old 13th November 2020, 04:38 PM
I did check if heating system working fine and also I setup steering temp on 36’ Steering wheel received a new gearshift paddles
ID:	24494   Click image for larger version
ID:	24495   Click image for larger version
