Hey folks, last year I battled the dreaded headlight bulb swap and finally won! Last week the dash binged to say a bulb was now out. Feeling sick, I looked, DS was out. Switched it all on and off you do!) and its stayed on. But I get the dash symbol saying a bulb is out...
I could live with the dash being lit up for christmas. But would rather get to the bottom of it just in case it later does go off and stay off. Thoughts please folks... Appreciated ![]()
Usually huffing, puffing and buffing in a dark corner somewhere... |
Perhaps the ballast is on it's way out. You can try swapping them over and see if it shows the other side as faulty? Did you replace it with a good quality bulb?
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
Bought the bulb direct from our sponsors
![]() What will the ballast look like? Is it the part the bulb attaches in to?? Appreciate the response ![]()
I had an issue with intermittent display of one headlight bulb warning showing on my RS6, it would happen at random and would go away if I played about with switching them off and on a few times, I changed bulbs on both sides, (I wanted better/brighter bulbs) and also replaced the igniter on the offending side which seems to have sorted it. Problem with replacing more than one component is you never really know what caused it. The igniter is fairly cheap so probably worth replacing it at same time as bulb
Audi S8 2015, Daytona Grey |
