Apologies for the thread resurrection.
Does anyone know if following the OP method above and manually winding the piston in as described, after reassembling, is the EPB module able to figure out what the piston position should be? Is it just a case of putting it all back together and then doing a function test and it will all just settle down correctly? Also, is there some sort of gasket or seal between the motor housing and the caliper?
Phantom Black 2008 A8 3.0 TDI SE ASB |
I've only done this with VCDS, and have never had any problem after cleaning and replacing seals on the rear caliper. Would like to think though, that cycling the hand brake would do the trick too. Between the motor and the caliper, there is a O-ring with parts number 4E0615137.
2006 Audi A8 3.0 TDI Quattro Sport A8 W12/S8 Brakes front and rear (385mm/335mm) Focal and JBL speakers, Helix amps S8 anti-roll bars front and rear Complete rear LED taillight Xenon fog lights All interior LED S8 rims 9x20" Stage II tune S8 Grill |
Is it a thing on these cars that the rear caliper gets dogs abuse with caliper pistons getting corroded? - Replaced OSR caliper at 130k and now NSR at 140K.
Phantom Black 2008 A8 3.0 TDI SE ASB Last edited by dangerdred; 4th February 2021 at 05:55 PM. |
I was having a problem where one of my neighbours with two golden labsused to let both of them use my son's offside rear a urinal post. He fell out with me when I spoke to him about it. Not the dog's fault, always down to owners. I still have to have the occasional word with dog walkers not having poo bags with them.
