Buzzing noise in dash area
I recently had this annoying buzzing noise from behind the dash start and its getting worse now. Sometimes you can switch off the engine etc and start again and it doesn't happen.
It will do the buzzing noise with only the ignition on (ie no engine) so i'm pretty sure it not engine related. I can also hear a gurgling noise as well just before the buzzing starts - is there a pump or something behind the drivers dash area to do with the heating etc?
D2 2.8 Sport ('98 110,000miles and counting) |
Buzzing Noise - You may well be hearing one of your vent flap motors whirring away. They occasionally break one of the plastic teath on the vent flaps and there whirr away happily awaiting the stop signal which is never coming as the vent flap isn't moving. There are a few threads on here about the problem. Try searching 'vent flaps'.
Gurgling - The AC evaps have a tray inside the car that drains into the transmission tunnel. If they are blocked you get wet feet eventually and wet carpets almost certainly!. How to fix it is here.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
Aha - that would explain what I'm hearing.
Guess I need to get in under the dash to find which motor it is now then
A proper VCDS (VagCom) lead and soft ware will allow you to activate each motor individually so you can tell when the noise changes.
