Go Back   A8 Parts Forum > A8 D4 > D4 - Sat Nav, ICE, Audio & TV
D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus
Old 31st January 2019, 09:28 PM
Albert_Swafega Albert_Swafega is offline
Do you need the other 3 files that were on the initial website to load it properly?
Yes, if you've not updated it before, the basics for the D4 3GP MMI are:
1: Need to be on firmware K0900 or above (for patcher to activate map)
I used modified version of K0900 to avoid updates and possible sound problems (BOSE / B&O)
2: Follow instructions to delete and replace map partition with new map.
3. Activate (Patch) the software/map
4: Resolve fault codes with VCDS or similar
Future map updates will simply overwrite the existing map but have to be applied in user defined mode, which needs access enabled to the Green Engineering Menu.
I've updated mine every 6 months for the last 3 years
2011 A8 Executive 3.0 TDI Quattro
Old 2nd September 2019, 04:23 PM
latest 2019-2020 Euro 3GP map if anyone wants it....
8R0051884GH
please seed for a while after you've got it ��
Code:
magnet:?xt=urn:btih:C76FB2E38895B46EBB2801FCA94E6490373CAC9F&dn=3GPGH&key=550000000000000000000000500047005400597E761E1EB290F4C476C0A1AFD2&tr=udp%3a%2f%2ftracker.openbittorrent.com%3a80%2fannounce&tr=udp%3a%2f%2ftracker.opentrackr.org%3a1337%2fannounce
Old 15th September 2019, 02:16 PM
Finally got round to doing mine today, kept an 8A battery charger coupled up, with blowers and readio turned off.
Did it from USB under the arm rest this time instead of an SD card.
All went great as per usual, cleared the SVM error with VCDS and the help of https://www.audienthusiasts.com/Appl..._SVMError.html
Old 20th December 2019, 12:25 AM
H-M3 H-M3 is offline
Need to get this done on my one too. Any links tips?
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 21st February 2021, 06:13 PM
Here's a torrent for the Europe 2021 - 8R0051884HQ map:
Albert
Old 23rd February 2021, 12:32 AM
Albert
Cool. So how does one burn this to an SD card or something?
