Old 26th February 2021, 07:19 PM
Echo's Avatar
Echo Echo is offline
From what I can tell from the pics, you have Rear Seat Entertainment in your car?
If I'm reading the coding for your analogue tuner correctly, it's:
000 - all good
1 = RSE fitted
0 = A6/A8 model coding
03 = UK
At the moment it looks like the hybrid is coded for:
000 - all good
0 = NO RSE fitted
2 = model code, so presumably for A/S5
03 = UK
So basically you need to tell the TV module what the spec of your car is, so that it relays the right information for the MMI to pick up (assuming this module is actually compatible with your car)
It's unlikely to show anything on the MMI until the module is coded correctly
ETA - so in very basic terms, you need to copy that coding string that you use for the analogue tuner, and enter the same into the 'software coding' box, and click 'do it'. The little pop up box should guide you - wherever the ? appears, it's basically giving you a guide to which digit relates to which function from that list - hopefully explained as I've posted above
No rear stuff in there I'm afraid.
So, I put in: 0001003
Is that right Adrian?
2004 A8 D3 4E2 3.0ltr Petrol............baby A8
