Wow! You're brave. And I predict this will be the longest WITW thread. Ever.
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ![]() ![]() (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ![]() (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
Seeing all that makes me wonder (again) what eventually happened to the Avus Silver FE with RED interior (and 39-valve engine) that you picked up from near me?
That’s an impressive list!
Your work is cut out got this one. Good work saving an FE ![]() ![]()
Mudflaps are on the list twice. You must really dislike them
![]() I love mine..... ![]() Zip
2002 D2 S8: Ebony Black over Platinum. A8L Comfort front seats in black ( ![]() ![]() 2005 B6 S4 Cabriolet: Ebony Black Pearl over Silver. RNS-E, Bose, heated seats, cruise control, retrofit aux-in, centre armrest, Milltek resonated exhaust |
![]() ![]() I really hate them! They are so ugly I'd rather just wash the dirt off than have to look at them. Plus, these are hanging off anyway. The problem though is that removing them leaves screw holes in the trim to which they are attached. I may just have to refit them properly and try not to look at them. |
Maybe it's because they also trap muck around them? I worked out how to embed pictures, now I just need to work out how to make them smaller ![]()
2002 Mark's D2 S8 FE 2020 BMW M340d xDrive (Anely's daily driver) 2000 FL D2 4.2 QS - SOLD 2011 ![]() Last edited by sarg; 8th April 2021 at 09:04 AM. |
Then I saw some pictures of them on the superbly elegant PF D2 - wrong, just wrong, horribly wrong......
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 8th April 2021 at 09:51 PM. |
Started tinkering. I'd like to get it driveable without spraying oil everywhere and without sounding like the suspension is going to fall off, so that I can at least move it around.
One of the ARB link bolts was loose which won't have helped with the rattly suspension at all For some reason most of the broken things are on the front left corner so I'll start here I pulled the power steering pressure hose to get that repaired properly. The rod end came loose from the tie rod with a little persuasion Unfortunately the tie rod is totally stuck in the upright, but that doesn't matter since its getting changed anyway Cut the rod end in half with the angle grinder so I can get the upright off the car The CV boot is toast The suspension turret brace is cracked at the top so fell off as soon as I removed the lower bolt The rest of it is still in the top plate. I have spares of these so no matter. Both front disc back plates have their front edges worn off which is a bit odd The top rear arm has been completely ruined by spraying PS fluid, which is a shame as it was ok before that - the other side is fine. Pulled the whole suspension assembly off in one lump - I'll take most of it apart here then pull the top arms in the vice Messy in here but much easier to clean up with nothing in the way! The pinch bolt just came out! That was a pleasant surprise as I was expecting quite a fight. Parts which need repair or replacement just on this corner: CV boot (split) Steering rack boot (torn by whoever did the PS hose) Upper rear arm (ruined by PS fluid) Lower rear arm (ruined by PS fluid) Wheel bearing (grumbling) Headlight level arm (held on with a cable tie) Arch liner (work through by the tyre) Turret brace (snapped) Wing (bashed and broken) Bumper bracket (cracked when the wing was damaged) |
So good to have my morning reading back!
