Old 7th April 2021, 08:29 PM
Wow! You're brave. And I predict this will be the longest WITW thread. Ever.
Old 7th April 2021, 08:31 PM
Seeing all that makes me wonder (again) what eventually happened to the Avus Silver FE with RED interior (and 39-valve engine) that you picked up from near me?
Old 7th April 2021, 08:44 PM
RICKY D's Avatar
RICKY D RICKY D is offline
That’s an impressive list!
Your work is cut out got this one. Good work saving an FE
Old 7th April 2021, 09:09 PM
I still have the shell, out the back of the workshop. That's what will be donating avus body panels to save this one as the paint on the body is ruined, but the bolt-on bits are still ok.
Well, I didn't scrap the murple in the end, and that is still the worst D2 of all time. It might be a contest between the two of them!
Old 8th April 2021, 08:32 AM
Zip's Avatar
Zip Zip is offline
Thumbs up
Mudflaps are on the list twice. You must really dislike them
I love mine.....
Zip
Old 8th April 2021, 08:51 AM
I love mine.....
Zip
I totally hadn't noticed that! I guess I must have put it on the list for the front and then again when I got to the back
I really hate them! They are so ugly I'd rather just wash the dirt off than have to look at them. Plus, these are hanging off anyway. The problem though is that removing them leaves screw holes in the trim to which they are attached. I may just have to refit them properly and try not to look at them.
Old 8th April 2021, 08:56 AM
sarg sarg is offline
I love mine.....
Zip
I was worried it was just me, my QS had mudflaps, anything that helps prevents crap getting kicked up on to the paintwork is a good thing in my eyes
Maybe it's because they also trap muck around them?
I worked out how to embed pictures, now I just need to work out how to make them smaller
ID:	26108   Click image for larger version
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 8th April 2021, 05:58 PM
Ooops, sorry, missed this comment in your admittedly comprehensive description!
I have avus body parts from my dead one (which is in an even worse state than this one as it doesn't have an engine or gearbox), so that one will be fully dismantled now to save this one
As for mudflaps…
:I really hate them! They are so ugly I'd rather just wash the dirt off than have to look at them.
I recall "back in the day" when I got my first S8 (nearly 20 years ago!) I discovered mudflaps were an option and thought - might be a useful protection.
Then I saw some pictures of them on the superbly elegant PF D2 - wrong, just wrong, horribly wrong......
Old 9th April 2021, 09:28 PM
Started tinkering. I'd like to get it driveable without spraying oil everywhere and without sounding like the suspension is going to fall off, so that I can at least move it around.
One of the ARB link bolts was loose which won't have helped with the rattly suspension at all
For some reason most of the broken things are on the front left corner so I'll start here
I pulled the power steering pressure hose to get that repaired properly. The rod end came loose from the tie rod with a little persuasion
Unfortunately the tie rod is totally stuck in the upright, but that doesn't matter since its getting changed anyway
Cut the rod end in half with the angle grinder so I can get the upright off the car
The CV boot is toast
The suspension turret brace is cracked at the top so fell off as soon as I removed the lower bolt
The rest of it is still in the top plate. I have spares of these so no matter.
Both front disc back plates have their front edges worn off which is a bit odd
The top rear arm has been completely ruined by spraying PS fluid, which is a shame as it was ok before that - the other side is fine.
Pulled the whole suspension assembly off in one lump - I'll take most of it apart here then pull the top arms in the vice
Messy in here but much easier to clean up with nothing in the way!
The pinch bolt just came out! That was a pleasant surprise as I was expecting quite a fight.
Parts which need repair or replacement just on this corner:
CV boot (split)
Steering rack boot (torn by whoever did the PS hose)
Upper rear arm (ruined by PS fluid)
Lower rear arm (ruined by PS fluid)
Wheel bearing (grumbling)
Headlight level arm (held on with a cable tie)
Arch liner (work through by the tyre)
Turret brace (snapped)
Wing (bashed and broken)
Bumper bracket (cracked when the wing was damaged)
ID:	26110   Click image for larger version
ID:	26111   Click image for larger version
ID:	26112   Click image for larger version
ID:	26113   Click image for larger version
ID:	26114   Click image for larger version
ID:	26115   Click image for larger version
ID:	26116   Click image for larger version
ID:	26117   Click image for larger version
ID:	26118   Click image for larger version
ID:	26120   Click image for larger version
ID:	26121   Click image for larger version
Old 10th April 2021, 08:37 AM
So good to have my morning reading back! ����
