Go Back   A8 Parts Forum > A8 D4 > D4 - Everything Else
D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out
Old 14th April 2021, 07:25 AM
allaheadfull allaheadfull is offline
Default How to check whether the A8 is a LWB or not.
Silly question, but without actually seeing the car in the flesh, how do I know if the car is a LWB version?
I know it should have the badge on the back (A8 L) but if that is missing is there an easy way to tell.
When I had a Phaeton LWB - all the LWB models had a sunroof, and the climate control in the rear between the seats was present (not in the SWB versions)
As I am in the market for one, it would be good to check from the pictures, before going to see one.
Many thanks,
Old 14th April 2021, 12:10 PM
In the D4 the LWB had electric seat adjustments in the rear as standard, also the rear door cards are and easy tel in interior pictures as the ashtray is much elongated
Old 14th April 2021, 01:20 PM
i'm not sure about the LWB having leccy seats as standard, but certainly the door storage bin is elongated on the LWB.
Below are LWB (left) and SWB (right). You can clearly see the different door bins in red, and the huge difference in the transmission tunnel length in green.
Hope that helps.
Old 14th April 2021, 01:48 PM
Default Easiest visual check
For me, the rear window shapes are the easiest exterior visual clue - the SWB is almost square shaped, whereas the LWB is definitely rectangular in shape.
Also, LWBs are pretty rare, I think...
Old 15th April 2021, 11:41 PM
H-M3 H-M3 is offline
Not all D4 LWB come with electric rear seats.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 16th April 2021, 11:02 AM
Thanks all - very useful, will update if I get close to buying one.
Only remaining question is Petrol or Diesel?
I would love a petrol - but they are rare, and the TDI's ones look to have good performance, and the fuel economy looks amazing, well from the figures at least, anything else to consider?
Old 16th April 2021, 12:23 PM
homer simpson's Avatar
Just check some of the usual D3 stuff. Sunroof and plenum drains do block, so make sure there are no signs of water ingress. Check the headlining doesn't have water stains and that the footwells (especially passenger) doesn't have signs of water ingress
