Yes disable it after you have lowered the car. Just don't forget to re-able it before you lift the car back up to put the wheels back on
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder |
're changing the bushes ,removing the arms is simple if the pinch bolts aren't seized,removing the old Bush's is simple ,I run a hole saw thru the rubber ,opened a hacksaw and put blade thru and reassembled saw and cut the sleeve and popped it out with a screwdriver,10 mins will take all 4 out ,now the fun part ,,i am lucky enough to have a neighbour with a 10 tonne press in his workshop which pressed them in very easy,the big issue was getting them to sit square to get them started ,we filed the leading edge by a mill or so just to help them start square as the arm is alu and the bush kept biting and going of square ,the edge we filled sits out of the arm so it shouldn't matter , 're loading the suspension i did more or less what mj had said ,thou i hadn't thought of disabling the Jack mode
Audi S8 D3 07MY 5.2 V10 Daytona Grey With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black |
There's an ever-so-slight chamfer on one side of the arms. The bushes only go in without biting if you push them through from that chamfered side. Might not have been your issue but thought worth posting for others in the future to be aware of.
I discovered this when doing the D2 rear suspension bushes. When the steel covered bushes started chewing the aluminium . . . .
2000 FL A8 3.7 QS - Turned 21 years old on 15th March 2021. Ming Blue - 175k miles. I love having a 90's car worthy of 90L of 98 RON! If only they still did 4* fully leaded! 2009 A8 4.2 FSi LWB - Marine Blue - 164k miles. Extras? Too many to list. But I do like the Rear Seat Entertainment . . . . . . 477k miles to the moon and back. 238k to go and between them they'll have made it! |
Famous last words!...What an absolute pig of a job this has turned out to be. The long pinch bolt was seized solid in the wheel bearing housing and after hammering it and heating it to no result, I remembered one tip I'd read in the comments in one of the youtube videos I'd looked at - snap the head off the bolt and then pull it through with the nut and washers. This was working a treat until I'd realised I'd trapped my ring spanner on the nut before getting it out fully so I ended up having to cut the bolt before the nut just to get my spanner out. I continued with the open end of the spanner until the bolt was fouling the wheel bearing housing knuckle so then I had to cut the bolt again after the nut. I then drove what was left of the bolt out of the housing with a metal drift I found at the bottom of my toolbox that looked like it hadn't been used in 20 years....I was probably at it close to two hours at this stage. Next came the ball-joints so off I went and bought a separator which snapped before it freed the first ball-joint I attempted. I hadn't used one of these before (quick bang of a lump hammer always did the trick) but it doesn't seem to be able to be used without damaging the ball-joint boot?
EDIT: I've a feeling the ball-joint tapers are seized into the aluminium in the same way the bolt was...
Phantom Black 2008 A8 3.0 TDI SE ASB Last edited by dangerdred; 2nd May 2021 at 12:15 AM. |
Once the pinch bolt is out I use a large tapered punch to push the upper arms out. Usually they need to be worked back and forth a bit to break the ring of corrosion around the pin where the pinch bolt goes.
I had the same problem ,I used a trolley Jack and a small round bar to apply heavy upward pressure on the pin in the track Rod and then taped the housing gently and prolonged and pin eventually started to move ( it's not that easy to get the bar and Jack positioned to get the strong upward pressure as part of the suspension stops u from getting directly under it)(same as yourself I didn't want to damage the rubber boots ) ,I think I cleaned the corrosion out of the slit with a hack saw blade and sprayed penetration oil into it before hand as well ,when I went to the second side i just rung the head of the bolt right away and pulled it thu with the nut as it seemed to be the only thing that worked on mine
Are you doing this on the bench or on the car?
Phantom Black 2008 A8 3.0 TDI SE ASB |
On the bench - I never do control arms on the car. The principle should still work on the car, but you're swinging the hammer in an awkward direction of course.
I had tried the punch method on the car but couldn't get a good enough thump at it to free it with the hammer so moved on to the Jack and bar
#30
Indeed, no swing could be had with a hammer with the bearing housing on the car so I decided to take your lead and remove the whole assembly until I ran into the same problem again (only worse!) with the tie-rod ball-joint. The pinch bolt is seized solid and there doesn't even seem to be a bolt head to shear off to pull it through like I did with the other one. I had liked the idea of pulling out the whole assembly as the arms could then be torqued up to the referenced angle on the bench (if I read the manual correctly?) not to mention full access to my arch liner as I have a washer fluid leak issue to look at while I'm in there as well. Quote:
