D2 - Lights Headlights, xenons, foglights. Everything outside the car that glows |
Hi all
Do we have a solution for this NLA part? 4D0505465G? Thanks Frank
Audi S8 D2 2002 88k mls Ebony pearl effect black. Grey interior. |
Two solutions. I prefer to make a new linkage from M6 race car ball joints and some M6 stainless threaded rod. I cut the original ball joint off the metal bracket which goes round the control arm (assuming its salvageable) and bolt the race car joint to it.
The more stock option is to buy an aftermarket sensor for the C5 A6 which usually comes with a new arm. Press out the bushings and ball joints from both arms and press the new ones back in to the original D2 plastic arm. |
I never considered that... That's brilliant!
-Andrew 1967 Bus 1980 Rabbit Pickup 1992 Corrado 2001 S8 2010 Jetta TDI Cup Edition |
It's normal for MJ. Her 'normal' is our 'brilliant'!
2002 D2 S8 - Avus Silver, Valcona red leather, Dark Myrtle wood inserts, Heated rear seats, Heated windscreen, Auto dim rear view mirror, Bose, Xenon Plus, Servotronic, Extended leather, Heat & UV Reflective glass & Ski hatch. Gearbox went bang but she's sleeping safely away. |
Or are you making a few for general sale?? ![]()
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
How odd. Never seen one melted like that - has someone tried to weld it back together?
If you make a set and get the length slightly wrong then the headlights will need to be recalibrated which is simple enough with VCDS. I can make the balljoint sets on exchange if needed. |
