Old 24th May 2021, 12:03 PM
Prefferle Prefferle is offline
Default S8 Front stabiliser bar rubber bushings UK supplier?
Hi All,
I know there have been many discussions on this point for the 31mm S8 sport bonded ARB bushings however, no one has posted a UK supplier or solution that does not involve buying a new Anti-Roll Bar complete with the bonded bushings.
There should be no issue with applying non-bonded bushings since this is the prevailing design in the industry, also given the high potential suspension travel the bonded bushing was not the best idea anyway, being prone to failure.
Can someone let me know a UK supplier even if it’s for poly-bushings or rubber?
Thanks👍
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
Old 29th May 2021, 04:31 AM
Default Update on ARB
Hi,
UPDATE
So I contacted all the poly bush company’s I could find here in UK and no one does an aftermarket Anti-roll bar / Front stabiliser bar bush kit - so no luck.
So I bit the bullet and called my mate at the VW dealership and ordered the complete ARB.
That’s all the control arms replaced with Meyle-HD arms on the S8. A lovely car and worth every penny to sort out.
Keep up the great forum👍
Present cars
Old 29th May 2021, 05:43 PM
homer simpson's Avatar
Originally Posted by Prefferle View Post
Hi,
UPDATE
I could only find them for the upper and lower control arms and the link rods too. May polybush all of mine when they need replacing. Not sure whether to go for the standard purple ones or Black Series?
Old 5th June 2021, 03:50 PM
I think the black series may be too stiff losing some drive refinement transmitting more vibration through to the chassis... then again may be far better handling...
Present cars
Old 5th June 2021, 04:50 PM
That's exactly what I was thinking. I don't need it to be a stiffer, will only tempt me to drive it harder and lose my license
The comfort for a sports chassis is perfect so I don't really want to compromise that either. Standard ones it is then!
