Old 22nd June 2021, 12:41 AM
Stromaluski's Avatar
So I did indeed mill down the rear diff mount yoke 2mm off each side makes it the same size as the D3 yoke
D3 mounts now fit perfectly Happy to do these on exchange with or without bushings if anyone else wants one, since its not really a DIY task.
These are Febi, and as usual you can see where the Audi rings have been ground off post-production. Its actually an A6 part rather than unique to the D3 so easily available for £12 each.
Question here. From what I've read, I can simply use the entire D3 bracket/bushings rather than modifying the D2 bracket to accept the D3 bushings? Is that true?
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
