Old 12th December 2010, 06:20 PM
Default RNS-E in an S8 - should the instrument cluster show turn by turn directions?
Hi all
Test drove a D2 S8 today - it has RNS-E retrofit but a couple of things I'm not sure about - I believe you should have turn by turn directions showing up in the DIS? I know when I test drove an A4 with RNS-D it did this - not knowing if the S8 DIS is the same style or not, wasn't if I'm (a) missing something obvious like pressing a button or (b) it's not been coded/connected properly to work?
I 'believe' the unit has a bluetooth module, but when I tried to connect my phone I couldn't find a menu option under 'tel' or 'setup' to search for my phone. I found an option to enter the PIN for bluetooth, but that's it. What usually happens when you press the 'tel' button if there is no bluetooth?
I stupidly forgot to press the TV button to find out if that worked......
I believe the unit was installed professionally but there's no receipt to show what was done or by whom....
Adrian
