Old 7th July 2021, 06:32 AM
There's no connection between the gearbox in limp mode and the fuel pump. If its been stood for a while then its entirely feasible both have failed at the same time, being two of the most problematic bits of the car.
The only way the F125 can cause a no-start condition is if it fails to engage the neutral relay when in P or N - that is a relatively common problem as the contacts in the switch burn out or simply fall off. The starter doesn't engage at all then though - you turn the key and nothing happens. That doesn't put it in limp mode though because the TCU doesn't care about that circuit. If its turning over and not starting then the neutral switch is ok. Instant PRNDS when you turn it on is mostly a sign of 'F125 implausible', but also can be symptomatic of a wet TCU getting solenoid and valve body issues on power-up.
Is the rev counter moving when you try to start it?
Old 7th July 2021, 07:26 AM
As MJ says, the F125 can also stop the car starting, as happened to me, but it's separate circuits inside the unit (re starter relay) and it won't turn over, so not the problem here.
Old 31st July 2021, 11:32 AM
Originally Posted by Green Goblin View Post
Amazing coincidence considering it’s your old car Goran (hope you’re well btw) - I have the exact same problem! Car turns over but refuses to start, however I have all the transmission lights lit up on the dash. Could this be fuel pump as well? Or F125?
I must admit, I can’t hear the fuel pump when I first turn the key but would failure of that cause all the transmission lights to light up?
FYI - there is loads of power from the batt because I keep a CTEK MXS 7.0 connected when it’s not being driven. Turns over smooth as ice and very fast.
EDITED TO ADD - Oh I noticed your post was 19th June - did you fix your car? Was it the fuel pump?
Hi! Glad to hear you still have the car.
It seems around the 20 year mark is around the limit for these old fuel pumps. I guess 20 years work is very good for a brushed motor fuel pump.
I still haven't got round to starting on mine, been abroad for a few weeks.
I have the new pump already, but now I have to hunt around for all the seals and washers etc before I can start the job. And I'll have to buy some cheap run around car until this is fixed. What a pain.
I hope you get yours sorted. These are such nice cars, there is nothing new that can replace them.
Old 2nd August 2021, 01:50 PM
*edit - wrong thread
