Old 19th August 2021, 09:56 AM
Ronin Ronin is offline
Default Mirrors keep folding
I have a new issue on the A8.. as soon as i start the car or turn ignition on the mirrors start to fold and it doesn't stop until I remove the fuse..
Would this be a wiring issue or more of a replacement module job?
VCDS scan doesn't show any problems
Old 19th August 2021, 10:17 AM
My initial thought would be a dodgy switch, so take out the drivers door switch panel, disconnect that circuit and observe.
I've done it several times but forgotten exactly how, I think you have to lever off the door handle shell from below first. Maybe some screws/bolts too?
Old 19th August 2021, 11:01 AM
Usually the relay is full of water as its right under botang's hole. Relay box top left, I think number 362.
Old 19th August 2021, 11:49 AM
"I defer to my learned friend". Also a lot easier to get at and replace.
Old 15th January 2022, 05:59 PM
To anyone reading this in the future, the fault was caused by a water damaged relay:
Relay number 361 in the passenger foot well:
