Old 20th August 2021, 08:27 PM
Mossyboy1978 Mossyboy1978 is offline
Default Replacement lambda sensor
Evening all
Just had new exhaust mid section fabricated with sports cats and new pipes (will upload a vid shortly). One of the post-cat lambda sensors is knackered and I need to buy a new one. ANy recommendations where to get from as Eurocarparts doesn’t seem to have anything.
Also - if anyone has a good ECU programmer that could delete the post cat sensors for me that would be a great help. Then I won’t need one at all!!
Many thanks
Mossy
2002 S8 Aqua Pearl, entirely original apart from FE 20" OEM wheels and Milltek exhaust.
Old 20th August 2021, 09:20 PM
The originals are £140 a pop so cheaper to get them mapped out. https://www.autodoc.co.uk/bosch/1149091
I don't have a map for it yet but should have fairly soon
Old 21st August 2021, 08:37 PM
I had both of my post-cat lambdas mapped out by MRC tuning 7 years ago, no problems since. I highly recommend them. It only cost £150.
I'm running either 100cell or 200cell HJS cats, cant remember which. Goes through MOT no problem.
They also mapped out and removed the secondary air pump (electric fan inside the airbox) which failed. Well worth doing also. That also requires removal of some of the vacuum hoses and blocking off ports on the back of the engine. I can't remember the cost of that, I'll look it up.
Physical work of removal cost £68. I can't find the re-coding cost.
Labour costs may be a bit higher now.
Old 23rd August 2021, 12:17 PM
Thanks to you both. Looking into the ECU cat delete now as Banbury is a bit far for me
Tags
exhaust, lambda, sensor
