Go Back   A8 Parts Forum > Our Other Audi Friends > Other Audis
Other Audis All other Audi related chat
Old 23rd August 2021, 09:41 PM
Default C5 Allroad Injector Refurbishment
I've stuck this here as it is the car I've done this on. However, the injectors are used on the 3.7and 4.2 used in petrol D3 A8s and the principle is the same for most petrol injectors pre FSI.
I was getting codes showing the offside bank was running either rich of lean to various degrees and having done a full service and changed the spark plugs, the next thing was a failing injector on that bank. I bought a second hand set of injectors from a D3 and had them cleaned and tested. All were within tolerance so I bought a refurbishment kit from Master Injector on eBay.
The kit contains 8 X filters, 16 X o rings and 8 X plastic washers to hold the lower o ring in place.
First remove the old o rings a plastic washer. Pin nose pliers pull the plastic washer off easily.
Next remove the old filter. I used a blunt self taping screw and pliers. Screw in to the filter until it just bites and pull the filter out with a bit of force and a wobble action.
Insert the new filter and gently tap it in until it's flush. I use a small wooden mallet.
Fit both the o rings and the plastic washer on the bottom. They all just push on. The plastic washer will rotate once on properly.
Repeat 7 more times.
Then reinstall.
My reading suggest that injectors should be cleaned and tested every 125 to 150k.
The refurbished injectors cleared all the faults on VCDS.
ID:	27058   Click image for larger version
ID:	27060   Click image for larger version
ID:	27061   Click image for larger version
ID:	27062   Click image for larger version
Old 23rd August 2021, 10:01 PM
Default Part nos?
Nice Mike - have you got the part number for the Thatchers Gold?
Old 25th August 2021, 11:38 AM
I buy them in bulk. 24 to a pack with a price break point at 5 packs. Last about a week when I'm working on the cars. 4 months if I'm not!
