The aux belt tensioner in the PF is part of the timing belt cover. Its a complicated affair which runs on a pair of needle roller bearings which I had to remove to get it powdercoated
Two new bearings, and I made a tool to press them in to place One of the bearings fitted The tensioner, complete with massive spring just waiting to go sproing and break something / someone Tensioner arm Assembled view from the back. I managed to put it together without scratching anything or the spring going sproing. I also fitted a new fan pulley bearing. I need this to finish the timing belt reassembly as the crank pulley locking tool fits in to the slot at the bottom of the cover Fuel line rubber doodads now free of rust They'll soak in rubber care solution overnight |
I put the inside of the inlet manifold back in and noted that this arrangement of vacuum pipes is very silly indeed, especially since it just flaps about.
Much better ![]() I finished off the timing belt setup and got the tensioners correct and the locking tools removed. Next job is to visit the local tractor workshop and see if they have a torque wrench that goes to 450Nm so I can do the crank pulley bolt ![]() I couldn't put the old rotten rubber seals on the beautifully powdercoated covers, so even though the price of new seals is £ ![]() Covers back on, and I'm pretty pleased with how smart they look Manky rotten rubber here would just have let the whole thing down |
Those covers are just lovely
Cars... '93 Audi Coupe 2.0 Alpine White (sold) '99 Audi S4 Merlin Purple - K04 upgrade to 412hp (sold) '00 Audi S8 Agate Grey (Sold ![]() '11 Audi Q7 4.2tdi Unknown Red (Classic Red Pearl Effect - thanks MJ) |
Just wondering, will the 32v timing belt covers fit on the 40v engines?
2001 S8 (build date March 16th 2001) Brilliant black with oxblood red/black interior. Mods prior to my ownership: 01E 6 speed, carbon fiber trim, bi-xenon, aftermarket muffler with x-pipe, tinted windows, non-tip steering wheel, Spal electric fan. My mods: Oxblood red interior, LED interior lights, D3 ignition coils, new window tint, tip steering wheel with new S8 emblem, mk1 TT steering wheel air bag, mk1 TT 6 speed shift knob, new shift boot. |
Very nice and interesting to see you working with AHC-engined PF S8, just like mine
S8 V10 '08 / 200 quattro 20V '90 / 944 Turbo '88 / 500 SEC '85 / 740i '94 Instagram @hptalli |
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
Put the throttle body back on
This bizarrely complicated mess of plumbing is all for the brake vacuum, and oddly it just flaps about, which causes the bottom joint to fail and allow air past the throttle body which will cause misfires and poor running. The original one was quite badly perished at the bottom. I had a spare set of pipes so put those on instead and gave the bottom joint some extra support with some adhesive-lined heatshrink Then drilled a hole in the upper part of the intake tube (which is mostly solid apart from a couple of holes for the idle valve) and tapped it to M6 and then made a P-clip to support the pipework. Its nice and solid now so no more flapping about |
Did an injector service and refitted them
Thats the engine done now, until its reattached to the gearbox, so on to the gearbox next ![]() |
Alas no, the 5HP is going back in. I don't have the mk2 clutch pedal finished or enough parts for another manual and, even if I had those, getting a manual AHC ecu is impossible.
