Old 26th August 2021, 05:19 PM
Heksi's Avatar
Heksi Heksi is offline
Very nice and interesting to see you working with AHC-engined PF S8, just like mine
S8 V10 '08 / 200 quattro 20V '90 / 944 Turbo '88 / 500 SEC '85 / 740i '94
Instagram @hptalli
Old 26th August 2021, 07:31 PM
Manky rotten rubber here would just have let the whole thing down
Better make sure the bonnet brackets and hinges are in good working order, predicting the new owner over using them showing off that engine.
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 27th August 2021, 08:46 PM
Put the throttle body back on
This bizarrely complicated mess of plumbing is all for the brake vacuum, and oddly it just flaps about, which causes the bottom joint to fail and allow air past the throttle body which will cause misfires and poor running. The original one was quite badly perished at the bottom.
I had a spare set of pipes so put those on instead and gave the bottom joint some extra support with some adhesive-lined heatshrink
Then drilled a hole in the upper part of the intake tube (which is mostly solid apart from a couple of holes for the idle valve) and tapped it to M6
and then made a P-clip to support the pipework. Its nice and solid now so no more flapping about
ID:	27115   Click image for larger version
ID:	27116   Click image for larger version
ID:	27117   Click image for larger version
ID:	27118   Click image for larger version
Old 30th August 2021, 08:12 PM
Did an injector service and refitted them
Thats the engine done now, until its reattached to the gearbox, so on to the gearbox next
ID:	27130   Click image for larger version
ID:	27131   Click image for larger version
ID:	27132   Click image for larger version
Old 31st August 2021, 07:42 AM
A manual gearbox?
Paul
Gosport UK
Honda Jazz
Old 31st August 2021, 09:11 AM
Alas no, the 5HP is going back in. I don't have the mk2 clutch pedal finished or enough parts for another manual and, even if I had those, getting a manual AHC ecu is impossible.
Old 31st August 2021, 12:20 PM
Ronin Ronin is offline
as a 2.8 AMX owner I'm jealous of the aluminum intake and better crank case ventilation pipes
That doesn't bode well for the future by the sounds of it - will that make any more conversions practically impossible, if such parts are unobtainable?
Old 31st August 2021, 12:29 PM
I think it just means, not with a PF 32-valve engine which AHC is I believe.
Did Audi ever make a manual PF or was it only after the facelift and 40-valve engines arrived?
Old 31st August 2021, 05:16 PM
I have seen a few PF manuals on the continent: https://www.reezocar.com/en/occasion...361963767.html
I Agree, one touch of the pipes and they are toast!
Paul
Gosport UK
Honda Jazz
