Old 25th January 2022, 09:12 PM
H-M3 H-M3 is offline
Default Notebook for vcds
Hi lovely people hope all is well. Just bit the bullet and purchased VCDS HEX NET. No I blew my budget so need a tablet/notebook under £100 if poss to use. I hope to add BMW diagnostics too in the future so any recommendations? Was looking at the Windows surface pro 3?? Thanks in advance.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 25th January 2022, 09:42 PM
Just get an old cheap used laptop, VCDS doesn't need anything modern.
Budget for a new battery......
Old 26th January 2022, 06:48 AM
Dell E5500 series are perfect for VCDS - cheap as chips ex-corporate machines, relatively robust, 15" screen, support Windows 10, and are plenty quick enough with an SSD.
Old 26th January 2022, 08:33 AM
Similar to that, I've got a Dell E6320 (upgraded to SSD and W10) and am now replacing it with a Dell XPS13 (SSD as standard) which is smaller and lighter.
And both were free, being thrown away (by different people) because of easily-fixable problems. The XPS13 was "dead" but just needed a battery-out reset and it's fine.
(Both, as noted elsewhere, now running Windows 11.)
Old 26th January 2022, 11:13 AM
homer simpson's Avatar
I use a Panasonic Toughbook CF-19. They are robust and can be used as a laptop or tablet. Reasonably priced these days, throw in a cheap SSD and away you go
https://www.ebay.co.uk/itm/363662881...3ABFBMwJ-V5tJf
Old 26th January 2022, 03:43 PM
I've got a 'free' Toshiba Portege I acquired - as above if it's any SSD based laptop it will boot really quickly and consume bugger all power. The battery is hidden inside the case, and although it's a bit below par it works fine for running scans etc. It's got an i5 processor and runs W10 absolutely fine.
Old 26th January 2022, 10:43 PM
Thanks All
